Kenb123co
Nov 23, 2020Aspirant
Can't Send Text Messages over WiFi
Xfinity modem, used to have several DLink Router/Access Points around the House. Got rid of them all and bought the RBK753 3 pack from Costco. One on each floor - awesome coverage. Since switchi...
Nov 23, 2020Guru - Experienced User
- Kenb123coNov 23, 2020Aspirant
Orbi is on V3.2.16.6_1.4.4
Xfinity Modem - ARRIS GROUP, INC. TG3482G
When I was using a bunch of Dlink Dir-323 attached I had zero problems, the problem started when I installed the Orbi and turned the Dlink off.
- FURRYe38Nov 23, 2020Guru - Experienced User
What mode is your modem working in? Router or Briged? If router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
