orbisteve
Apr 11, 2020Aspirant
Can't set up guest network name and security
Helping a friend set up a RBR850 2-pack system, so far everything has gone smoothly. However, we seem to be unable to set up a guest network. There is one that shows up, NETGEAR-Guest, on 192.168.2.x...
- Apr 25, 2020
I didn't get back to this for a couple of weeks for lots of reasons not the least being the pandemic. So when I went to look at it again I thought, "Hm, why don't I just give it another try via the 'usual' route with the web login?" And lo and behold this time it worked. The guest network name and password "stuck" and it doesn't just show Netgear Guest now. I swear I didn't do anything different, I didn't reset the router, I didn't use a different browser... nothing. It just for some reason worked. So, everyone's happy, though I'm a little irked because I'd like to know why it worked now but not before. But I'm not going to question it! No sir!
Thanks to all those who provided advice, and to everyone, please take good care and stay healthy!
orbisteve
Apr 25, 2020Aspirant
Apr 26, 2020Guru - Experienced User
Glad it worked. Wondering if something was just stuck and given some time off, finally got unstuck.
Enjoy and keep healthy. :smileywink:
- orbisteveApr 26, 2020Aspirant
Thanks for the reply. 24 hours later (give or take) and all seems well. There wasn't a firmware update or anything so it's still baffling. I'll just file this away under "mystery" unless someone else experiences this (and if they do the only advice I'll have is "just wait"). I've even looked through the logs and can't find anything different between the time it worked and the times it didn't. It's a win, though, since it works, and that's good enough!
- FURRYe38Apr 26, 2020Guru - Experienced User
Ya is very odd. Glad it's working now though. :smileywink:
