cjrichards007
Jun 11, 2021Aspirant
Can't Setup New RBK853 / RBR850 with Virgin Media Hub 4
I recently bought a refurbished RBK853, so 1 router with 2 satelittes. I am based in the UK (London), and currently signed up with Virgin Media 1gig broadband, delivered via their Hub 4 router. I...
- Jun 14, 2021
Thanks Fury, as mentioned, I did already have my router in bridge/modem.
Turns out when I did the factory reset on the Orbi router, I only got a solid amber light. When I tried again, I got the flashing amber light, and after that, the setup went as expected.
Thanks
Jun 11, 2021Guru - Experienced User
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
- cjrichards007Jun 14, 2021Aspirant
Thanks
- FURRYe38Jun 14, 2021Guru - Experienced User
Be sure to save off a back up configuration to file for safe keeping. Saves tine if a reset is needed.
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-SystemBe sure to mark your thread as solved. Enjoy,
- cjrichards007Jun 15, 2021Aspirant
That's a good point! Have just saved a backup, thanks!
