MrTony
Aug 15, 2022Follower
Can't update RBR850 router firmware
I'm having issues where numerous devices are being dropped on my wifi. To address the issue: 1. I started by performing a factory reset of the router and reconfiguring it. 2. I then started upd...
CrimpOn
Aug 15, 2022Guru - Experienced User
The screen shot is correct.
- Above the line means to browse to the location of the router firmware file.
- Below the line is a way to manually update satellites.
Click the Browse button above the line.
p.s. My personal practice is to ignore this method for updating satellites. I connect directly to each satellite using its IP address and select the menu item Firmware Update on the satellite's web page.
