mattg1960
May 30, 2022Star
Can't Update Satellite Firmware to Match Router
Thanks to Christina I was able to update the router firmware and it has mostly solved the problem, although I have had internet disconnections but they are no longer multiple times per day.
When I try to manually update the satellite firmware I get a pop-up window that times out before I can browse to select the file posted by FURRYe38.
The router firmware isV4.6.8.2 and the satellites are V4.6.5.14.
Any Ideas?
I kind of hate to pursue it as I have a 'good enough' solution...but I'd like the firmware of the RBR750 router and RBS750 satellites to match.
Try downgrading the RBR to v.14.
Have the v.2 RBS FW files at the ready on a PC once the RBR is downgraded long enough to get the RBS updated:
My router was updated by Christine to V4.6.8.2.
Since it (mostly) works, I do not want to mess with it.
I would just like my satellite firmware to match the router.
I downloaded RBS750-V4.6.8.2-signed.chk from your post but cannot apply it to the satellites because the pop-up window times out.
Why can I not choose the new file that you provided?
That is my question...thanks.
What popup window timing out are you seeing?
Please post a screen capture of what your seeing.
What browser are you using? Try MS Edge, Firefox or Opera
