yefanah
May 05, 2023Aspirant
Carrier Infinity Touch Thermostat will not connect
Tried many permutations but thermostat will not connect. Hoped that IoT 2.4 GHz network would do the trick but no luck. Experimenting with a WNDR 4500 old router showed that a CTS setting of 200 ...
CrimpOn
May 05, 2023Guru - Experienced User
Carrier thermostats have proved to be frustrating in the past. Is this the process you are following?
https://www.youtube.com/watch?v=UlSNVYIU3A0
(Perhaps you have a link to Carrier's WiFi setup instructions?)
yefanah
May 06, 2023Aspirant
The video is the procedure I followed. My experiment with the old Netgear WNDR 4500 involved setting it up the the same ssid and password, limiting it to 2.4 GHz, and doing a binary search type algorithm to find the smallest CTS setting that allowed the thermostat to connect -- 200 worked and 175 failed so the limit is somewhere in between. I made many connections and confirmed I was doing the Carrier process correctly.
I had hoped that once connected via the identical ssid/password to the 4500 that it would remain connected to the ORBI but no such luck. I have 4 thermostats, and none connects to the ORBI when previously they had all connected to an old Netgear or ASUS simple router.
