peppercorn
Jan 10, 2021Tutor
Carrier Infinity Touch Thermostat won't connect to Orbi RBK852 (AX6000) WiFi
I just replaced my Orbi RBK50 system with a new WiFi 6 Orbi RBK852 (AX6000) mesh system at my home. I kept the same WiFi network SSID and password from the RBK50 and all of my devices successfully a...
- Jan 10, 2021
Yes, NG is defaulting to 64 on there Orbi AX system which for some older devices or some Iot, doesn't work well so setting 2347 is a alternative solution. Glad you got it working. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
Jan 10, 2021Guru - Experienced User
Enjoy. :smileywink:
