peppercorn
Jan 10, 2021Tutor
Carrier Infinity Touch Thermostat won't connect to Orbi RBK852 (AX6000) WiFi
I just replaced my Orbi RBK50 system with a new WiFi 6 Orbi RBK852 (AX6000) mesh system at my home. I kept the same WiFi network SSID and password from the RBK50 and all of my devices successfully a...
- Jan 10, 2021
Yes, NG is defaulting to 64 on there Orbi AX system which for some older devices or some Iot, doesn't work well so setting 2347 is a alternative solution. Glad you got it working. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
Feb 09, 2021Guru - Experienced User
Use a wired PC and web browser and navigate to 192.168.1.1 or orbilogin.com.
Under Advanced Tab/Advanced Settings/Wireless Settings to change CTS values.
Arch666 wrote:Hi,
I saw the thread about Carrier Infinity Touch not able to connect to AX6000. I have the same problem but with AX4200 (RBS750)
The solution provided is - "change the CTS/RTS Threshold values to 2347 for both the 2.4GHz and 5GHz wireless settings."
How to do this? I am a non-tech person.. can someone please send the details (steps) please?
Thanks
Arch
Arch666
Feb 09, 2021Initiate
I followed th instructions.. thanks FURRYe38 (Guru) :)
My thermostat is connected to Orbi's network
