bowler304
Jan 31, 2023Tutor
Carrier Thermostat systxccitc01-b can't connect to Orbi AX6000 RBR850 / RBS8540
Hello, I have a carrier thermostat systxccitc01-b and it suddenly won't connect to my Orbi Router. The strange thing is it worked fine for almost a year. I found another thread to change the foll...
bowler304
Feb 01, 2023Tutor
"Make sure you tried a full reset of the networking on the thermostat (like "forget network") and then pair again to your Orbi wifi SSID."
I have done forget and set up 3 or 4 times now. It will connect but won't talk with their servers, but when I bring up my router settings it doesn't show the device is connected to the internet.
Feb 01, 2023Guru - Experienced User
So its connecting to the wifi?
Just not back to their server?
What modem/gateway is the router connected to?
Are you using Armor?
- bowler304Feb 01, 2023Tutor
So its connecting to the wifi? Yes
Just not back to their server? Correct
What modem/gateway is the router connected to? RBR850 / RBS850 (latest firmware)
Are you using Armor? Armour: Status: Not activated
It shows connect to the wifi
Remote Access Status
Network Status: connected
SSID: <correct network>
MyInfinity Data Server: not connected
MyInfinitiy OTA Server: not connected
When I connect to my hot spot on my mobile phone, they are all connected.
