All41's avatar
All41
Carrier Touch thermostat "A" will not connect to Orbi RBR850
TLDR:
Our Carrier Infinity Touch version "A" thermostat will no longer connect to our Orbi RBR850 or its satellite RBS850s after rebooting then resetting them. The thermostat connected to the Orbi Guest network for years.
No changes to either the Orbi or thermostat firmware, which are both up-to-date. I've now spent days trying to get a connection. The best I've gotten is a temporary connection by connecting the thermostat to something else (laptop, another WiFi access point) which has the same network name and password, then turning that off, which then appears to give me a connection to the Orbi system. I'm not even sure that's a real connection, as the Carrier remote app won't work with it, but the thermostat does show up in the Orbi web portal Attached Devices. Thermostat connects when the Orbi has encryption off.
Detail:
We had a lot of trouble connecting our Carrier Infinity “MyTouch” version A thermostat (SYSTXCCITC01-A) to our Orbi RBR850 several years ago. After that it’s been pretty stable. The thermostat has occasionally required a reboot by pulling it off the wall for a few minutes then reinstalling. The thermostat has been on the Orbi’s Guest network.
Recently we had some trouble with at least one satellite, so I did some rebooting, resetting, restoring from settings backup, and finally a full reset of the entire Orbi system with new manually entered settings based on screen shots of old settings from the web interface.
Early on in the rebooting process the Carrier “A” thermostat stopped connecting. I cannot get it to reconnect to the Guest network.
The Carrier A thermostat will connect to:
- laptop sharing Ethernet to WiFi, same network name & password as the Orbi Guest network.
Works both with and without the RBR850 WiFi on, with the laptop close to the thermostat. I discovered that the laptop uses the same router IP address as the Orbi guest network, 192.168.2.1, and assigned an IP address which doesn’t conflict with the other two devices on the Guest network.
- Apple Time Capsule, Ethernet to the RBR850, Orbi WiFi off, same network name & password as Guest network.
It put the thermostat on the main Orbi network, IP 10.0.0.0.x.
For both the laptop and the Time Capsule if I turn them off the thermostat appears to stay connected to the Guest network for a few minutes. The thermostat shows up in the Orbi web interface under “Attached Devices” as a Redpine Signals device. (The thermostat does not show up in Attached Devices while it’s on the laptop or the Time Capsule. The laptop I think is doing double NAT, but the Time Capsule is not.)
The thermostat also connects to:
- iPhone as a hotspot, different network name and password.
- RBR850 Guest network with no encryption.
The Carrier A thermostat will not connect to:
Any combination of the Orbi with encryption, on main network, IoT network, or Guest network, satellites on or off, will not work. The top encryption the thermostat has is WPA2. The bottom encryption the Orbi offers is WPA. Tried both.
I once got a connection to the main Orbi network, but I’m not sure how. Haven’t been able to replicate that, and I want it on the Guest network anyway.
Other notes:
  • No changes to either the Orbi or thermostat’s firmware. Both are latest firmware. RBR850 is v7.2.7.15._5.1.16
  • The thermostat is 2.4 GHz only.
  • WiFi scan with my phone at the thermostat gives RSSI -56 to -62 dBm on the Guest network. Neighbors' are in the -80s.
  • The thermostat has no local network control. Remote control is only through Carrier’s server via Carrier’s phone app.
  • Carrier claims that their thermostats don’t work well with mesh systems. But it won’t connect when I have only the RBR850 on. And, it will connect when there’s no encryption.
  • We also have a Carrier Touch “B” thermostat and a Ting sensor on the Guest network. These reconnect if they or the Orbi system lose power. They (or at least the B thermostat - the Ting is too close to the router) are able to shift from the Orbi to the laptop and back, and from the RBR850 to an RBS850.
  • Our two satellite RBS850s are connected to the RBR850 via ethernet. (We have a third RBS850 not currently connected because it shows up as an “Attached Device” instead of a satellite - that’s another issue.)
  • The Orbi has these settings in Advanced>Advanced>Wireless in the web interface:
    • Enable 20/40 MHz Coexistence is OFF.
    • CTS/RTS Threshold (1-2347) is set to 2347.
Carrier suggests I get a cheap TP-Link router, connect it to the Orbi router, and use it’s default settings to connect the thermostat (!). I don’t want to do this because it adds additional WiFi traffic and can’t be put on the Guest network. We have an AT&T gateway. It’s possible I could put the TP-Link on that, or use the gateway’s own WiFi, currently off. But the gateway sits next to the RBR850.
I’ve also thought about trying a WiFi repeater, but it would still add WiFi traffic.
Carrier’s “B” thermostats go for $400-$500 on eBay used. They now have a “C” thermostat, which is closer to $1000 on eBay. Plus a service call to set it up.
Any ideas?
    • FURRYe38's avatar
      Would be something to just disable IPv6 on the RBR first to check that.
      • All41's avatar
        All41
        It is possible that the RBR850 did a firmware update along the way that I didn't see. I do have auto-update enabled. But it seems to me that I've looked at firmware several times in recent months, as I've had ongoing problems with one satellite, and I don't think it has changed. What I did do was to reinstall the current version of the firmware on the router and the satellites in case something had gotten corrupted. But this was after the thermostat wouldn't connect. It didn't help with the thermostat, or the one RBS850 not showing up as a satellite. Also, the Netgear page for the latest firmware says updated 2/24/25. I'd think auto-update would have done its thing before the thermostat problem, which only started last week.
        I don't see a way to disable IPv6 looking at Advanced>Advanced>IPv6. Would it be the drop down across from "Internet Connection Type", which currently says DHCP, but has an option for "Disabled"? Not sure I want to do that for the entire router, although I'm not up on how important IPv6 is as of today.
        How would I get an older version of the Orbi firmware? I assume I'd need the older version for both the router and the satellites. But again, I'm not sure I want to have to use older firmware. Updates include security fixes . . .
    • All41's avatar
      All41
      Yes, I've tried the main Orbi network, the IoT network with both 2.4 GHz and 5 GHz and just 2.4 GHz enabled, and the Guest network.
      Neither WPA2-PSK [AES] or WPA-PSK [TKIP] + WPA2-PSK [AES] work.
      I've done pretty much everything suggested in the search link you posted. The one thing I didn't mention is that Access Control isn't enabled.
      • FURRYe38's avatar
        Not sure if the others that posted ever got a good resolution aside from installing a 2ndary wireless AP.
        Wondering if you installed this 2ndary AP long enough for the device to connect. Set for same SSID name and PW as what is on the Orbi system, then once you get the devices connected to the AP fully, just turn OFF the AP and see if these devices auto migrate and connect to the Orbi signal. I would set the Orbi signal to WPA2 only to help test this as there maybe some wifi devices that do not like having WPA3 on the signal, even though they don't support it, won't connect if it's enabled. Ran in to this early days of my 850. NG removed WPA3 until this was worked out and brought it back in 2023.
        I would presume if the devices connect to the 2ndary AP using same SSID name and PW, then turned off, if they don't connect to the Orbi system, maybe some odd connection issue that the device Mfr needs to take a look into with NG. I know we saw bad problems with NEST controllers back in 2020 as well. Caused the NEST batteries to drain due to the controller not keeping locked on to one signal and ping ponging back and forth trying to decide which signal to lock onto since there was many signals coming from the MESH system. NG and NEST had to work on this to get it figured out. Not fully sure if they ever did as one work around for this was to wire connect the controllers to the HVAC system that provided lower power current to the controllers. Ever since making this switch, I haven't looked back. However the controller do connect to Orbi signals. Something this device mfr should take a look into.
  • My Trane thermostat (along with some of my cameras) would not connect when my IPv6 connectivity dropped using firmware v7.2.7.15._5.1.16. Just an idea, I went back to v7.2.6.31_5.0.24 and everything connected again.
