jcat71
Oct 08, 2020Tutor
CAX80 vs CBR750
Other than the CBR having mesh satelittes, what are the differences? What the sq. ft coverage are for each router? Speed comparisons? etc? Not sure which to purchase. My house is 40' wide by 45'...
Oct 08, 2020Guru - Experienced User
Check the spec sheets for each of these models.
Sq ft of home is preferred.
I've got the CAX80 and it works well in a 5000sqft home. For additional coverage, I use two EX7700s as extenders and works well though they are not AX supporting.
