jcat71
Oct 08, 2020Tutor
CAX80 vs CBR750
Other than the CBR having mesh satelittes, what are the differences? What the sq. ft coverage are for each router? Speed comparisons? etc? Not sure which to purchase. My house is 40' wide by 45'...
jcat71
Oct 08, 2020Tutor
I'll probably end up with the CBR. I'm more interested in speed consistency across the whole range. Plus the aethestics will work better wall mounted in sight.
The nighthawk like seems interesting but at a similar price point and spec I guess I don't see point for my use case, which is primarily streaming sticks at the TVs, cell phones and smart devices.
Thanks for your input.
Oct 08, 2020Guru - Experienced User
Good Luck with what you decide. :smileywink:
