atejwani
Aug 20, 2021Apprentice
CBK 752 Firmware updates (CBR750 -V4.6.3.6, RBS750 -V4.6.3.7) dropped downloads speed!!!
Prior to CBK 752 Firmware updates (CBR750 -V4.6.3.6, RBS750 -V4.6.3.7), I was consistently getting 1.2gb - 1.4gb download speeds. Now it is below 650mb. Nothing else, besides the firmware updates, ha...
atejwani
Aug 24, 2021Apprentice
Answers below in Bold.
Blanca_O wrote:
Hi atejwani
May we please know who is your Internet Service Provider?
Xfinity - Comcast - Service: 1.2gb Down/40mb Up
Please check your inbox. I have sent you a message requesting for more information.
Replied to private message.
Blanca
Community Team
cin8
Sep 09, 2021Tutor
Hello, did you get this issue resolved? I'm having the same exact problem after the firmware update. Seems from the research I've been doing, will just have to wait for another FW update.
Thank you!
Thank you!
- FURRYe38Sep 10, 2021Guru - Experienced User
Please reach out to a forum moderator to see what options are available for you.
Thank you!- cin8Sep 10, 2021TutorThanks! I found a tip on another thread about this. It suggested to connect a laptop or desktop directly via a LAN port on the CBR750 and test the speed through the Speednet app. I used the Windows download of it. The speed was accurate. No significant drop. I'm not too concerned anymore about the inaccurate number through the Orbi app or the onboard web interface.
- cin8Sep 11, 2021TutorHave still reached out to the forum moderators for the Beta bc the CBR750 has been rebooting on its own several times a day now.
