atejwani
Aug 20, 2021Apprentice
CBK 752 Firmware updates (CBR750 -V4.6.3.6, RBS750 -V4.6.3.7) dropped downloads speed!!!
Prior to CBK 752 Firmware updates (CBR750 -V4.6.3.6, RBS750 -V4.6.3.7), I was consistently getting 1.2gb - 1.4gb download speeds. Now it is below 650mb. Nothing else, besides the firmware updates, ha...
Sep 10, 2021Guru - Experienced User
Please reach out to a forum moderator to see what options are available for you.
cin8 wrote:
Hello, did you get this issue resolved? I'm having the same exact problem after the firmware update. Seems from the research I've been doing, will just have to wait for another FW update.
Thank you!
cin8
Sep 11, 2021Tutor
Thanks! I found a tip on another thread about this. It suggested to connect a laptop or desktop directly via a LAN port on the CBR750 and test the speed through the Speednet app. I used the Windows download of it. The speed was accurate. No significant drop. I'm not too concerned anymore about the inaccurate number through the Orbi app or the onboard web interface.
- cin8Sep 11, 2021TutorHave still reached out to the forum moderators for the Beta bc the CBR750 has been rebooting on its own several times a day now.
