atejwani
Aug 20, 2021Apprentice
CBK 752 Firmware updates (CBR750 -V4.6.3.6, RBS750 -V4.6.3.7) dropped downloads speed!!!
Prior to CBK 752 Firmware updates (CBR750 -V4.6.3.6, RBS750 -V4.6.3.7), I was consistently getting 1.2gb - 1.4gb download speeds. Now it is below 650mb. Nothing else, besides the firmware updates, ha...
cpmassen
Sep 13, 2021Apprentice
Looking for a beta firmware for the CBR750 also. Thanks
Sep 13, 2021Guru - Experienced User
Hopefully NG will come out with something. Please be patient.
- cpmassenSep 13, 2021Apprentice
Thanks. Was just posting in this forum so I could get update notifcations for new posts
FURRYe38 wrote:Hopefully NG will come out with something. Please be patient.
since you directed me to it. I wasn't aware it existed.- FURRYe38Sep 13, 2021Guru - Experienced User
- atejwaniOct 04, 2021Apprentice
Hello Blanca, Darren and Furrye38 - Blanca_O , DarrenM , FURRYe38 ,
It has been about 6 weeks since these firmware upgrades were introduced and have degraded performance of our modem router/satelite. I have spent several hours with Netgear support personnel, who have just asked for more and more logs and I have not seen a solution from them. For now, I have given up on Netgear Engineering/R&D/Support providing any update firmware, be it beta.
There are bits and pieces of from various users, spread across various Netgear Orbi products - RBK752/3. RBK852/3, RBR750, RBR850, RBS750, RBS850,CBR750, CBR40, etc. and "rolling" back firmwares to prior versions on Netgear Community posts and Reddit posts!!!
Can Netgear Support to put together a "FAQ" with steps, which versions of firmware to "roll-back" to, and specific to the products, such as CBK752?
Thanks in Advance,
Al.
