atejwani
Aug 20, 2021Apprentice
CBK 752 Firmware updates (CBR750 -V4.6.3.6, RBS750 -V4.6.3.7) dropped downloads speed!!!
Prior to CBK 752 Firmware updates (CBR750 -V4.6.3.6, RBS750 -V4.6.3.7), I was consistently getting 1.2gb - 1.4gb download speeds. Now it is below 650mb. Nothing else, besides the firmware updates, ha...
rmarcare
Dec 27, 2021Apprentice
Were your issues fixed or did you replace the setup?
cpmassen
I’m still having issues with the satellite connecting to my Samsung TV. Tonight the tv was connected and upon researching it the Satellite was out of sync. As soon as I synced the satellite back the TV immediately lost connection. I’ve reported it and tried everything and no fix supplied at all yet
- cin8Dec 27, 2021TutorNot sure if you tried this yet, but the satellite also has a factory reset pinhole. I previously had issues with my satellite and factory reset it and haven't had an issue since. Also, if there's a delete button next to the satellite listing when you view the connected devices (through the webpage), I would go ahead and delete it too.
I am on all of the current firmware and after factory resetting both modem/router and satellite, I've had over 30 days of uptime.
