bnwbass
Aug 22, 2020Aspirant
CBK40 with existing R7960P Nighthawk
Upgrading my xfinity speed and purchased cbk40 system with /modem/router. I have been using a Nighthawk R7960P as the acces point extenter for my current xfinity issued cable modem which will be gon...
Aug 24, 2020Guru - Experienced User
If you want to keep using the R7960Ps wifi, then install 1 EX7700 or EX8000 extender to help with wifi coverage of the home.
bnwbass
Aug 24, 2020Aspirant
Thanks,
I have now purchased a C7800 and will use with the existing R7960P and then install 1 EX7700 or EX8000. This will give me ISP of 1gps
Thx
Bw
- FURRYe38Aug 24, 2020Guru - Experienced User
I would configure the R7960P for AP mode then disable the wifi radios on the C series modem.
