Ely
Mar 24, 2021Luminary
CBK752 Different firmware versions for Main unit and the satellite?
Hi there all, I hope I'm posting this in the right place, otherwise please feel free to move it and apologies in advance if this is the case. Yesterday I got my new CBK752 which I had purchased fr...
- Mar 24, 2021
Ya, since the RBS is use on the RBK7 series system there is a more recent update for the RBS. I presume at some point NG will update the CBR aswell. You should be ok in meantime.
Ely
Hey FURRYe38 thanks a lot for your reply.
I have the following firmware:
CBR750 V3.2.16.18
RBS750 V3.2.17.12
I appreciate your help.
-Eli
Mar 24, 2021Guru - Experienced User
- ElyMar 24, 2021Luminary
Thanks again, I guess I only need to wait for future updates, it still cannot update on its own though, it says it could not connect to the server. I'll be on the watch for new firmware from NG and update manually again when it they release it.
Thanks bud.
- FURRYe38Mar 24, 2021Guru - Experienced User
:smileywink:
