Kelitk79
Oct 18, 2020Aspirant
CBK752 frequent drops and loss of Internet
I recently upgrade to the brand new Orbi CBK752 Cable Modem/router and Mesh Router. I previously had a surfboard Docsis 3.1 modem and linksys ea9300 router. Living in a two story house I found myself...
Oct 19, 2020Guru - Experienced User
Is the drops happening with both wired and wireless devices?
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
- Kelitk79Oct 19, 2020Aspirant
Hello,
What Firmware version is currently loaded:
Router CBR750: v3.2.16.9, Satellite RBS 750 v3.2.16.6 (no updates)
1800sq ft
What is the distance between the router and devices?
Xbox(s), PC, Smart TV are between 15 to 30 feet away from the Satellite
Drop only happens on the wireless devices on the 2nd floor. Tv on the first floor that is "Wired" does not lose connection.
Where in the home is the CBR located? Main or 1st floor centrally is recommended:
CBR is on the first floor.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.Try disabling the following and see:
Armor, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).
I have implemented these changes and will follow up after testing the network.- Kelitk79Oct 20, 2020Aspirant
Well, I have had only 2 drops that I"m aware of after implementing your suggestions, so still not acceptable for a $600 setup .
Also, both my kids Xboxs are now getting Strict NAT Types and Double NAT detected which is impacting their ability to play.
I found the following link and was curious if this could be done on an Orbi Mesh setup and if so, how.
Or if you have a more updated fix that would help with the drops, Open the NAT and clear the Double NAT error that would be great. Or I'll be force to return this.
- FURRYe38Oct 21, 2020Guru - Experienced User
Might try the system with out the RBS as well to see if the problem comes at the CBR or not...
Is there a NAT Filter option under Advanced Tab/Wan Setup?
IF there is, change it to OPEN.
