Robert888
Jun 27, 2021Aspirant
CBK752 Power Adapter 2.5A or 3.5A?
Bought a CBK752 (AX4200) from US but want to buy an AU power adapter. US power adapter indicates 2.5A but user manual indicates 3.5A. wondering which is correct before I buy AU power adapter ...
- Jun 27, 2021
Just curious your cable TV ISP does allow using customer supplied cable mdem/routers in Australia.
FWIW, the CBK752 Data Sheet does state
What’s In the Box?
• One (1) Orbi Cable Modem Router (CBR750)
• One (1) Orbi Satellite (RBS750)
• One (1) 19V/3.16A power adapter (router)
• One (1) 12V/2.5A power adapter (satellite)
Jun 27, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi with Cable modem product. Most of the people who watch that forum are more likely to have experience with Orbi with Cable modem and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
Thank you.
