Pluto_9
Jul 02, 2023Aspirant
CBR 750 modem / router connection issues with ISP
Upgraded from R7000 Nighthawk to Orbi 750 CBR AX 4200 Modem Router Combo worked really well for first 6 months or so until the ISP did an upgrade in my area moving my speed tier to 1200 MBPS. Fo...
Jul 02, 2023Guru - Experienced User
It is compatible with CC/XF, just not with there 1.2Gb speed tier services. You'll need to downgrade to 800Mpbs.
The ISP changed there speed tiers last year which 1Gb was there max speed plan, which the CBR750 supports. When they split this into 800 and 1.2Gb plans and bumped everyone up to the 1.2Gb plan, this caused problems for the CBR750 which both ISP and NG is aware off.
Technically the modem side can handle the 1.2Gb speed, it's the router and LAN ports on the CBR that won't ever see anything past 1000Mpbs since the LAN ports on the back of the CBR are 1G max only. Which is why 1Gb was working until the ISP made the change.
We've gone round and round with other users about this. Only thing that seems to make the CBR work is the 800Mpbs speed tier since the ISP doesn't put out the 1Gb any more
- Pluto_9Jul 02, 2023Aspirant
Hi Furry,
Thanks for the information. The firmware I'm running is V4.6.14.4_2.3.12
I just checked on downgrading my service to the 800mbps which seems like going backwards for such a touted high end product as Orbi "The Rolls Royce" of wifi.
Apparently, Xfinity wants to charge more for the 800mbps service ($20.00 more per month) than they do for the 1.2GB service. So it will cost even more monthly. Fells like NetGear needs to make this right somehow. A $600 product that claims to be GB compatible 3.1 docsis future proof suddenly becomes a giant paper weight so soon after purchase.
I've been a Netgear fan for years, but this is leaving a pretty bad taste for such an expensive product.
Not sure downgrading service is the right move here.
Purchasing a router / modem combo in this case really backfired. First time and last time for that especially since the combo in this case cannot be used as a router with another modem.
- FURRYe38Jul 03, 2023Guru - Experienced User
You can certainly contact NG support and open a support ticket and let them know:
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/about/contact-us/All this is between NG and the ISP. Nothing else we can do here about it. Once reason I personally don't recommend gateway units. ISPs can change there policy and configurations, leaving some modems and users out. Having separate units offers better flexibility for users to maintain control over there units.
NG Gateway modes have never supported using them as routers. There primary function is the modem. The only modes NG supports for Gateway modems is modem only mode and router mode. Same with other Mfrs. Some don't even support modem mode.
You can use the CBR in a faux wireless AP Mode however. Turn OFF the DHCP service on the CBR and connect it to a host router and use the wifi portion of the CBR. I've done with with mine and it works.
Good Luck.
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
