Scooterk13
Jul 29, 2023Aspirant
CBR 750 Wi-Fi speed slow
I have an Orbi CBR 750 and two satellites on Spectrum gigabit. On the Orbi app, I see 1146 mbps download and 37 mbps upload. On wireless devices, the best I see is 500 mbps download and 34 Mbps upload...
Scooterk13
Jul 30, 2023Aspirant
Thanks for the response. The device is an iPhone 13 Pro and 500 Mbps is the best I get on ooakla standing right next to the orbi.
Jul 30, 2023Guru - Experienced User
have you tested other devices?
- Scooterk13Jul 31, 2023AspirantMy gaming computer using a Nighthawk A7000 Wi-Fi adapter sitting near to one satellite is getting 235 Mbps download and 38.48 Mbps upload.
- Scooterk13Jul 31, 2023AspirantWhen I plug an Ethernet cable directly into the Orbi satellite from the computer it goes up to 441 Mbps upload and the download is about the same at 36.
- FURRYe38Jul 31, 2023Guru - Experienced User
You would be getting good speeds for the devices your testing with at the RBS.
https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
https://www.duckware.com/tech/wifi-in-the-us.html
