bcphifer83
May 09, 2023Follower
CBR750 — Orbi WiFi 6 DOCSIS 3.1 Mesh WiFi Cable Modem Router
Hello All, we recently purchased the CBR750 — Orbi WiFi 6 DOCSIS 3.1 Mesh WiFi Cable Modem Router system two months ago while we had Spectrum Cable. We now switched to Fios and can’t figure out if thi...
May 10, 2023Guru - Experienced User
The CBR requires the use of the coax cable line to connect to a cable ISP system.
The only thing you can do is to turn the CBR into a faux AP mode and use it as a wireless access point behind another router: https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/Orbi-CBR40-connecting-to-AT-amp-T-210-router-need-help/m-p/2303958/highlight/true#M3993
