Retired_Member
Mar 09, 2023CBR750 - Downstream light blinking
hey all, Just got an Orbi CBR750 the other day and had comcast come in and replace all the lines. I'm seeing my downstream light continuously blink. Any troubleshooting advice would be greatly ap...
Retired_Member
Mar 10, 2023Here's a fresh one
| Time | Priority | Description |
| Mar 08 2023 20:18:01 | Critical (3) | Config File Rejected due to Invalid or Unexpected TLV 11 |
| Mar 08 2023 20:18:11 | Warning (5) | RCS Partial Service |
| Mar 08 2023 20:18:19 | Alert (2) | CM Certificate Error |
| Mar 09 2023 07:16:43 | Critical (3) | No Ranging Response received - T3 time-out |
| Mar 09 2023 12:32:18 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Mar 09 2023 12:32:18 | Notice (6) | TLV-11 - unrecognized OID |
| Mar 09 2023 12:32:18 | Critical (3) | Config File Rejected due to Invalid or Unexpected TLV 11 |
| Mar 09 2023 12:32:28 | Warning (5) | RCS Partial Service |
| Mar 09 2023 12:32:36 | Alert (2) | CM Certificate Error |
| Mar 09 2023 12:37:40 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Mar 09 2023 12:37:40 | Notice (6) | TLV-11 - unrecognized OID |
| Mar 09 2023 12:37:40 | Critical (3) | Config File Rejected due to Invalid or Unexpected TLV 11 |
| Mar 09 2023 12:37:50 | Warning (5) | RCS Partial Service |
| Mar 09 2023 12:37:59 | Alert (2) | CM Certificate Error |
| Time Not Established | Critical (3) | No Ranging Response received - T3 time-out |
| Mar 09 2023 16:44:16 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Mar 09 2023 16:44:16 | Notice (6) | TLV-11 - unrecognized OID |
| Mar 09 2023 16:44:16 | Critical (3) | Config File Rejected due to Invalid or Unexpected TLV 11 |
| Mar 09 2023 16:44:26 | Warning (5) | RCS Partial Service |
| Mar 09 2023 16:44:34 | Alert (2) | CM Certificate Error |
| Mar 09 2023 17:11:38 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Mar 09 2023 17:11:38 | Notice (6) | TLV-11 - unrecognized OID |
| Mar 09 2023 17:11:38 | Critical (3) | Config File Rejected due to Invalid or Unexpected TLV 11 |
| Mar 09 2023 17:11:48 | Warning (5) | RCS Partial Service |
| Mar 09 2023 17:11:56 | Alert (2) | CM Certificate Error |
| Mar 09 2023 17:35:12 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Mar 09 2023 17:35:13 | Notice (6) | TLV-11 - unrecognized OID |
| Mar 09 2023 17:35:13 | Critical (3) | Config File Rejected due to Invalid or Unexpected TLV 11 |
| Mar 09 2023 17:35:22 | Warning (5) | RCS Partial Service |
| Mar 09 2023 17:35:31 | Notice (6) | CM-STATUS message sent. Event Type Code: 5 |
| Mar 09 2023 17:35:31 | Alert (2) | CM Certificate Error |
| Mar 09 2023 17:51:11 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 |
| Mar 09 2023 17:51:11 | Notice (6) | TLV-11 - unrecognized OID |
| Mar 09 2023 17:51:11 | Critical (3) | Config File Rejected due to Invalid or Unexpected TLV 11 |
| Mar 09 2023 17:51:21 | Warning (5) | RCS Partial Service |
| Mar 09 2023 17:51:29 | Alert (2) | CM Certificate Error |
| Mar 10 2023 10:21:39 | Critical (3) | No Ranging Response received - T3 time-out |
Mar 10, 2023Guru - Experienced User
Ya theres line issues here. The ISP needs to review all Alerts, Criticals and Warnings and resolve them.
- Retired_MemberMar 10, 2023
Thanks for taking a look. Will give comcast a call and see if they can fix it.
- FURRYe38Mar 10, 2023Guru - Experienced User
Something else to try, someone else posted that they reloaded the CBR750 with the FW update file using a wired PC and web browser, factory reset and setup from scratch help them as well. Something to try in mean time when you can while you wait for the ISP to review the logs.
