Retired_Member
Mar 09, 2023CBR750 - Downstream light blinking
hey all, Just got an Orbi CBR750 the other day and had comcast come in and replace all the lines. I'm seeing my downstream light continuously blink. Any troubleshooting advice would be greatly ap...
Retired_Member
Mar 10, 2023Thanks for taking a look. Will give comcast a call and see if they can fix it.
Mar 10, 2023Guru - Experienced User
Something else to try, someone else posted that they reloaded the CBR750 with the FW update file using a wired PC and web browser, factory reset and setup from scratch help them as well. Something to try in mean time when you can while you wait for the ISP to review the logs.
