riq90210's avatar
riq90210
CBR750 & CBK 753, WILL THE ROUTER IN THE 753 SYSTEM BECOME A SATELITE WHEN USED WITH CBR750 MODEM.
My current modem died out looking for a replacement. I have the CBK 753 system, My thinking was maybe add the CBR750 and have the CBK 753 system be ALL satelites or will the CBK router not be utilized.
  • FURRYe38's avatar
    If you meam the RBK753 system and the RBR750 from that kit, then NO. RBRs only work as routers or in AP mode.
    • riq90210's avatar
      riq90210
      Yes, that was what I wanted to know the rbr750 from the kit as a satélite with the addition of the cbr 750 as the new router and modem. Thanks, I thought maybe it had the option to change it as an extender satelire
