Disturbd1
Aug 18, 2022Star
CBR750 + RBS750 - Satellite will not re-link with CBR unit
As description outlines, my 2 year old system is going to be the death of me...if it's not every WifI 6 device favoring 2.4gHz instead of 5, or never favoring the closest AP, then the satellite is ou...
ekhalil
Aug 18, 2022Master
If the satellite is synched and you can attach devices to it, then this must be a database issue in the CBR unit, as it looks that nothing is wrong with the satellite unit.
If you tried all what you mentioned you tried (including CBR restart?) then I think that your only option now is factory reset of the CBR.
Good luck!
