bigdave3395
Jul 20, 2021Follower
cbr750 & rbs750 cannot connect wireless device to satellites
cannot connect my wireless devices to the satellites rbs750 only to the main router cbr750. I have a blue light on each satellite showing they are connected to the main router but nothing can conne...
Jul 20, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Orbi With Cable modem products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/bd-p/en-home-orbi-cable
Thank you.
