hopperdropper
Jul 16, 2021Aspirant
CBR750 abruptly died, can't be reset
Hi, I purchased a CBK752 (base + 1 sat) as an open box special from Amazon. I set it up (easy), fiddled with a couple of my iOS devices but everything was working great. Fast...great coverage. Th...
Jul 16, 2021Guru - Experienced User
Why can't you reset it?
did you try pushing and holding the reset button for 7-15 seconds while the device is powered on?
I'd recommend trying that with the coax disconnected from it.
hopperdropper
Yes...disconnected, connected - all of the combos. The ring light goes to amber but it still doesn't broadcast the default SSID (or any SSID)
- plemansJul 16, 2021Guru - Experienced User
are you able to hardwire a pc/laptop into it?
- hopperdropperJul 16, 2021Aspirant
Yes but I can't get in with 198.x. I don't even get the browser challenge
"browser challenge?"
did you try 192.168.100.1
Try a different pc/browser?
