hopperdropper
Jul 16, 2021Aspirant
CBR750 abruptly died, can't be reset
Hi, I purchased a CBK752 (base + 1 sat) as an open box special from Amazon. I set it up (easy), fiddled with a couple of my iOS devices but everything was working great. Fast...great coverage. Th...
hopperdropper
Yes...disconnected, connected - all of the combos. The ring light goes to amber but it still doesn't broadcast the default SSID (or any SSID)
Jul 16, 2021Guru - Experienced User
are you able to hardwire a pc/laptop into it?
- hopperdropperJul 16, 2021Aspirant
Yes but I can't get in with 198.x. I don't even get the browser challenge
- plemansJul 16, 2021Guru - Experienced User
"browser challenge?"
did you try 192.168.100.1
Try a different pc/browser?
Browser challenge - the username/password dialogue box
When I set it up, I did so using Chrome w/o incident. After it bricked, I used the same browser, also in Incog mode to no avail. It doesn't work w/ Safari either
Neither 198.168.1.1 nor 198.168.100.1 works
It is just dead, unfortunately
