BKWayne
Jan 16, 2023Aspirant
CBR750 Address Reservation and Port Forwarding not working
Model: CBR750 FW: V4.6.14.4 Just got this router today. When I go to set static IPs via Address Reservation I'm hit with "400 Bad Request" and this is occurring with several devices. When I go ...
- Jan 16, 2023
What browser are you using? Does it happen with a different browser?
Try a full factory reset and setup from scratch using a web browser and wired PC.
Be sure to clear out all browser caches before entering the CBRs web page at 192.168.1.1
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
BKWayne
Using Firefox. Switching to Chrome solved it!
Jan 16, 2023Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
