LA2
Mar 01, 2023Aspirant
Cbr750 after firmware update, no internet
3/1/23. I had a notice of a firmware update on the Orbi app. I updated and now the is no internet connection. Orbi has been rebooted multiple times by myself and from Cox's end. We unplugged it for 10...
- Mar 01, 2023Sorry for the late reply. I have been working on this and have it working now.
I connected a laptop via wire to the Orbi and logged into it. I found that the firmware update had reset all connections to "blocked". I set each to "allow", and am able to connect now.
Thank you for your reply and help.
Mar 01, 2023Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System?
If you can access the CBRs web page using a wired PC and web browser, please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
- LA2Mar 01, 2023AspirantSorry for the late reply. I have been working on this and have it working now.
Thank you for your reply and help.- FURRYe38Mar 01, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡- LA2Mar 01, 2023AspirantThank you!
