SilkyJohnson
Aug 10, 2023Aspirant
CBR750 and fiber
I have a CBR750 and we are about to get fiber. What do I have to do to make my Orbi system work with fiber. I want my Satellites to function with whatever change needs to be made to the CBR750 modem/...
Aug 10, 2023Guru - Experienced User
the CBR is a Cable ISP connecting system. It wont work with Fiber. Only think you can do is to configure a Faux AP mode on the CBR and then connect one of it's LAN ports to a host router.
