SilkyJohnson
Aug 10, 2023Aspirant
CBR750 and fiber
I have a CBR750 and we are about to get fiber. What do I have to do to make my Orbi system work with fiber. I want my Satellites to function with whatever change needs to be made to the CBR750 modem/...
SilkyJohnson
Aug 11, 2023Aspirant
I have a CBR 750 modem. We are about to get fiber. I want to know if I purchase a RBS750 router will my current satellites work with the RBS 750? Do I just need to get a RBS750 router to make my current set up function with fiber? Thanks.
- FURRYe38Aug 11, 2023Guru - Experienced User
Do you mean getting a RBR750>?
- SilkyJohnsonAug 11, 2023Aspirant
Yes. That's exactly what I meant. Will my current satellites work with an RBR750?
You'll need to get the RBS and new RBR set up on same FW versions. However yes, they will work with a RBR750.
- KevinLiTAug 14, 2023NETGEAR Moderator
Hello SilkyJohnson ,
Welcome to the NETGEAR Community!
The RBR750, RBR840, and RBR850 are all compatible with your current RBS750 and can be used with your fiber configuration.
Best,
Kevin
Community Team
