SilkyJohnson
Aug 10, 2023Aspirant
CBR750 and fiber
I have a CBR750 and we are about to get fiber. What do I have to do to make my Orbi system work with fiber. I want my Satellites to function with whatever change needs to be made to the CBR750 modem/...
Aug 11, 2023Guru - Experienced User
Do you mean getting a RBR750>?
SilkyJohnson
Aug 11, 2023Aspirant
Yes. That's exactly what I meant. Will my current satellites work with an RBR750?
- FURRYe38Aug 11, 2023Guru - Experienced User
You'll need to get the RBS and new RBR set up on same FW versions. However yes, they will work with a RBR750.
