crowell33
Mar 11, 2022Aspirant
CBR750 and random disconnecting wireless
Been a loyal Orbi user for a few years now. My previous setup included a CBR40 with two RBS50 satellites; everything worked perfect. A couple of weeks ago, I upgraded my 400 Mbps Spectrum service to ...
CrimpOn
Mar 11, 2022Guru - Experienced User
Sorry to have gone off on that tangent about satellite models. (The forum provides endless opportunities make a fool of myself.)
Is it correct to assume that there are numerous other devices that never lose connections?
When the MacBook and iPhone lose connection, they often spontaneously recover without any action on your part?
When these interruptions occur, does the WiFi symbol disappear and the device Network Settings indicate that there is no WiFi connection?
Or, does the WiFi connection remain, but there is no longer internet access?
When one of these devices is interrupted, does the Orbi 'app' (or the Orbi web interface Attached Devices) indicate that the device is no longer connected?
Would you happen to know if these two devices have the 'Private MAC' address set to "Use hardware MAC" or "create Private MAC"?
- crowell33Mar 11, 2022Aspirant
No need at all to apologize. YOU'RE helping ME. :)
Correct
Incorrect. In order to reconnect, I need to turn off WiFi, then turn it back it on. It will then reconnect.
Correct.
See above.
I don't know, but I will test this tomorrow morning.
To my knowledge, this is not supported in macOS, only iOS, iPadOS and watchOS. (https://support.apple.com/guide/security/wi-fi-privacy-secb9cb3140c/web)
Having said that, yes; it is enabled on her iPhone.
- CrimpOnMar 11, 2022Guru - Experienced User
I struggle to understand "I-Things". Found one article about private address on MacBook that seems to indicate that it changes the MAC address every 8 hours on MacBook and iOS devices:
https://turbofuture.com/internet/How-to-Turn-Off-Private-Address-on-iOS-Devices
I do not have a Macbook or iPhone to test on. Would it be possible for you to change the setting to "off" and see what happens?
- crowell33Mar 12, 2022Aspirant
Just disabled on her phone, so we'll see what happens.
Thank you!
