LA2
Mar 04, 2023Aspirant
Cbr750 can't setup after reset
The cbr750 received a firmware update last week. I had problems and thought it was solved in this discussion. https://community.netgear.com/t5/Orbi-with-Built-in-Cable-Modem/Cbr750-after-firmware-upda...
- Mar 06, 2023
There is a link at the bottom of the page telling you to download the orbi app. Link says if you have a mobile device, select here. This takes you thru the web browser based setup wizard/
Ensure your WiFi adapter drivers are up to date.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
LA2
Need to add, I was stuck in a loop during setup in the app. When it says to connect via wifi to Orbi and I entered the password, I received a message to sign in to connect to the network. When I clicked on the message a window opened showing to download the app and connect through it. Gee, isn't that what I already did?
