jaws4
Feb 28, 2023Follower
CBR750 compatible to RBR750
Hi, I am trying to use both CBR750 Wifi System with built-in Cable Modem + 1 Satellite and RBR750 Tri-Band Mesh WiFi 6 System + 1 Satellite.
Once both are installed we still have issues with staying connected / spinning ..Could it be that there is setting that not enabled or disable ??
Devices:
6 SmartTV
9 Cell phone
4 Ipads
9 laptop
5 Gaming PC
2 PS4's
1 xboxOne
1 Nintendo switch
2 Kindle Reader
Thank you
1 Reply
No.
I recommend that you put the CBR into modem only mode and connect the RBS that came with the CBR and connect it to the RBK750 system and use the RBK750 system as the main host wifi MESH system.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
