bcfleischmann
Aug 23, 2022Aspirant
CBR750 Constantly disconnecting
Can you update how your system has been operating since your factory reset a month ago? I am having similar issues with my system dropping and just trying to troubleshoot which COA I need to consider...
bcfleischmann
Firmware. CBR V4.6.5.8_2.0.54 RBS 4.6.5.14
1650 sqft house. I disconnected one satellite because of reading about 30 ft. CBR is downstairs, RBS is upstairs. I assume it is the CBR disconnecting constantly because nothing works on wifi when disconnects happen until I reboot.
These changes I made two days ago.I changed settings to channel 1 for 2.4G and my 5G was already at channel 48. I set short preamble, unchecked the 20/40MHz coexistence, and set power thresholds to 50% for both 2.4 and 5G. I have previously disconnected for 1 minute on multiple occasions, and once since I made the above changes.
- bcfleischmannAug 23, 2022Aspirant
Aug 23 2022 15:14:39 Critical (3) SYNC Timing Synchronization failure - Loss of Sync Aug 23 2022 15:14:50 Notice (6) CM-STATUS message sent. Event Type Code: 2 Aug 23 2022 15:15:14 Critical (3) SYNC Timing Synchronization failure - Loss of Sync Aug 23 2022 15:15:24 Notice (6) CM-STATUS message sent. Event Type Code: 5 Aug 23 2022 15:17:36 Critical (3) SYNC Timing Synchronization failure - Loss of Sync Aug 23 2022 15:17:44 Notice (6) CM-STATUS message sent. Event Type Code: 5 Aug 23 2022 15:18:54 Critical (3) SYNC Timing Synchronization failure - Loss of Sync Aug 23 2022 15:19:04 Notice (6) CM-STATUS message sent. Event Type Code: 5 Aug 23 2022 15:19:25 Critical (3) SYNC Timing Synchronization failure - Loss of Sync Aug 23 2022 15:19:31 Notice (6) CM-STATUS message sent. Event Type Code: 5 Aug 23 2022 15:19:50 Critical (3) SYNC Timing Synchronization failure - Loss of Sync Aug 23 2022 15:19:51 Notice (6) CM-STATUS message sent. Event Type Code: 2 Aug 23 2022 15:19:52 Critical (3) SYNC Timing Synchronization failure - Loss of Sync Aug 23 2022 15:20:03 Notice (6) CM-STATUS message sent. Event Type Code: 5 Aug 23 2022 15:20:10 Critical (3) SYNC Timing Synchronization failure - Loss of Sync Aug 23 2022 15:20:10 Notice (6) CM-STATUS message sent. Event Type Code: 5 Aug 23 2022 15:21:48 Critical (3) SYNC Timing Synchronization failure - Loss of Sync Aug 23 2022 15:21:56 Notice (6) CM-STATUS message sent. Event Type Code: 5 Aug 23 2022 15:22:44 Critical (3) SYNC Timing Synchronization failure - Loss of Sync Aug 23 2022 15:22:44 Notice (6) CM-STATUS message sent. Event Type Code: 5 Aug 23 2022 15:31:22 Critical (3) SYNC Timing Synchronization failure - Loss of Sync Aug 23 2022 15:31:28 Notice (6) CM-STATUS message sent. Event Type Code: 5 Aug 23 2022 15:32:23 Critical (3) SYNC Timing Synchronization failure - Loss of Sync Aug 23 2022 15:32:33 Notice (6) CM-STATUS message sent. Event Type Code: 5 Aug 23 2022 15:43:17 Critical (3) SYNC Timing Synchronization failure - Loss of Sync Aug 23 2022 15:43:22 Notice (6) CM-STATUS message sent. Event Type Code: 5 Aug 23 2022 16:10:53 Warning (5) MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 Aug 23 2022 16:10:53 Notice (6) TLV-11 - unrecognized OID Aug 23 2022 16:10:53 Critical (3) Config File Rejected due to Invalid or Unexpected TLV 11 Aug 23 2022 16:10:57 Warning (5) REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value Aug 23 2022 16:10:57 Warning (5) RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW Aug 23 2022 16:10:57 Warning (5) RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW Aug 23 2022 16:11:07 Alert (2) CM Certificate Error Aug 23 2022 16:11:11 Notice (6) CM-STATUS message sent. Event Type Code: 3 Aug 23 2022 16:23:08 Warning (5) DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value - FURRYe38Aug 23, 2022Guru - Experienced User
Please post a copy and paste of the modems connection status page.
I see lots of criticals that the ISP needs to resolve.
Does the CBR show any front LED at the bottom or the 4 LEDs near the top of any odd behaviors here when this happens?
- bcfleischmannAug 23, 2022AspirantI will once the website allows me. Should be soon.
