bcfleischmann
Aug 23, 2022Aspirant
CBR750 Constantly disconnecting
Can you update how your system has been operating since your factory reset a month ago? I am having similar issues with my system dropping and just trying to troubleshoot which COA I need to consider...
bcfleischmann
Firmware. CBR V4.6.5.8_2.0.54 RBS 4.6.5.14
1650 sqft house. I disconnected one satellite because of reading about 30 ft. CBR is downstairs, RBS is upstairs. I assume it is the CBR disconnecting constantly because nothing works on wifi when disconnects happen until I reboot.
These changes I made two days ago.I changed settings to channel 1 for 2.4G and my 5G was already at channel 48. I set short preamble, unchecked the 20/40MHz coexistence, and set power thresholds to 50% for both 2.4 and 5G. I have previously disconnected for 1 minute on multiple occasions, and once since I made the above changes.
bcfleischmann
| Aug 23 2022 15:14:39 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync | ||||||||
| Aug 23 2022 15:14:50 | Notice (6) | CM-STATUS message sent. Event Type Code: 2 | ||||||||
| Aug 23 2022 15:15:14 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync | ||||||||
| Aug 23 2022 15:15:24 | Notice (6) | CM-STATUS message sent. Event Type Code: 5 | ||||||||
| Aug 23 2022 15:17:36 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync | ||||||||
| Aug 23 2022 15:17:44 | Notice (6) | CM-STATUS message sent. Event Type Code: 5 | ||||||||
| Aug 23 2022 15:18:54 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync | ||||||||
| Aug 23 2022 15:19:04 | Notice (6) | CM-STATUS message sent. Event Type Code: 5 | ||||||||
| Aug 23 2022 15:19:25 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync | ||||||||
| Aug 23 2022 15:19:31 | Notice (6) | CM-STATUS message sent. Event Type Code: 5 | ||||||||
| Aug 23 2022 15:19:50 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync | ||||||||
| Aug 23 2022 15:19:51 | Notice (6) | CM-STATUS message sent. Event Type Code: 2 | ||||||||
| Aug 23 2022 15:19:52 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync | ||||||||
| Aug 23 2022 15:20:03 | Notice (6) | CM-STATUS message sent. Event Type Code: 5 | ||||||||
| Aug 23 2022 15:20:10 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync | ||||||||
| Aug 23 2022 15:20:10 | Notice (6) | CM-STATUS message sent. Event Type Code: 5 | ||||||||
| Aug 23 2022 15:21:48 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync | ||||||||
| Aug 23 2022 15:21:56 | Notice (6) | CM-STATUS message sent. Event Type Code: 5 | ||||||||
| Aug 23 2022 15:22:44 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync | ||||||||
| Aug 23 2022 15:22:44 | Notice (6) | CM-STATUS message sent. Event Type Code: 5 | ||||||||
| Aug 23 2022 15:31:22 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync | ||||||||
| Aug 23 2022 15:31:28 | Notice (6) | CM-STATUS message sent. Event Type Code: 5 | ||||||||
| Aug 23 2022 15:32:23 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync | ||||||||
| Aug 23 2022 15:32:33 | Notice (6) | CM-STATUS message sent. Event Type Code: 5 | ||||||||
| Aug 23 2022 15:43:17 | Critical (3) | SYNC Timing Synchronization failure - Loss of Sync | ||||||||
| Aug 23 2022 15:43:22 | Notice (6) | CM-STATUS message sent. Event Type Code: 5 | ||||||||
| Aug 23 2022 16:10:53 | Warning (5) | MIMO Event MIMO: Stored MIMO=-1 post cfg file MIMO=-1 | ||||||||
| Aug 23 2022 16:10:53 | Notice (6) | TLV-11 - unrecognized OID | ||||||||
| Aug 23 2022 16:10:53 | Critical (3) | Config File Rejected due to Invalid or Unexpected TLV 11 | ||||||||
| Aug 23 2022 16:10:57 | Warning (5) | REG-RSP-MP Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value | ||||||||
| Aug 23 2022 16:10:57 | Warning (5) | RNG-RSP CCAP Commanded Power Exceeds Value Corresponding to the Top of the DRW | ||||||||
| Aug 23 2022 16:10:57 | Warning (5) | RNG-RSP CCAP Commanded Power in Excess of 6 dB Below the Value Corresponding to the Top of the DRW | ||||||||
| Aug 23 2022 16:11:07 | Alert (2) | CM Certificate Error | ||||||||
| Aug 23 2022 16:11:11 | Notice (6) | CM-STATUS message sent. Event Type Code: 3 | ||||||||
| Aug 23 2022 16:23:08 | Warning (5) | DBC-REQ Mismatch Between Calculated Value for P1.6hi Compared to CCAP Provided Value |
- FURRYe38Aug 23, 2022Guru - Experienced User
Please post a copy and paste of the modems connection status page.
I see lots of criticals that the ISP needs to resolve.
Does the CBR show any front LED at the bottom or the 4 LEDs near the top of any odd behaviors here when this happens?
- bcfleischmannAug 23, 2022AspirantI will once the website allows me. Should be soon.
Huh? You can't access the CBR web site?
