stardustdron
Mar 24, 2021Guide
CBR750 Downstream LED always blink white light
My Orbi CBR750 is getting internet connection from my ISP router via LAN connection and its always blink its downstream LED white light all days. I really want to turn it off but in the settings, t...
Mar 24, 2021Guru - Experienced User
Blinking usually means its scanning for a downstream channel.
do you have a screen snip of the cable connections page? That shows the link status
- stardustdronMar 24, 2021Guide
Here's the screenshot of the cable connection:
- plemansMar 24, 2021Guru - Experienced User
Photos have to be approved by a moderator. You can click on "choose file" and add them 1 at a time (only allows 1 per post) and they're accessible right away
I have attached it as file
