stardustdron
Mar 24, 2021Guide
CBR750 Downstream LED always blink white light
My Orbi CBR750 is getting internet connection from my ISP router via LAN connection and its always blink its downstream LED white light all days. I really want to turn it off but in the settings, t...
Mar 24, 2021Guru - Experienced User
Blinking usually means its scanning for a downstream channel.
do you have a screen snip of the cable connections page? That shows the link status
stardustdron
Mar 24, 2021Guide
Here's the screenshot of the cable connection:
- plemansMar 24, 2021Guru - Experienced User
Photos have to be approved by a moderator. You can click on "choose file" and add them 1 at a time (only allows 1 per post) and they're accessible right away
- stardustdronMar 24, 2021Guide
I have attached it as file
Nevermind, i uploaded it in imugr
You have no locked upstream or downstream channels.
Is your connection working? I've never seen one without locked/downstream upstream working. :)
Did you get it activated by your ISP?
check your coax for kinks, damage, old/bad/cheap connectors.
Remove any splitters, amplifiers, or attenuators from the line.
Ensure you're connected to the coax where it enters the home to ensure you have a direct connection.
