stardustdron
Mar 24, 2021Guide
CBR750 Downstream LED always blink white light
My Orbi CBR750 is getting internet connection from my ISP router via LAN connection and its always blink its downstream LED white light all days. I really want to turn it off but in the settings, t...
stardustdron
Mar 24, 2021Guide
Nevermind, i uploaded it in imugr
Mar 24, 2021Guru - Experienced User
You have no locked upstream or downstream channels.
Is your connection working? I've never seen one without locked/downstream upstream working. :)
Did you get it activated by your ISP?
check your coax for kinks, damage, old/bad/cheap connectors.
Remove any splitters, amplifiers, or attenuators from the line.
Ensure you're connected to the coax where it enters the home to ensure you have a direct connection.
- stardustdronMar 24, 2021Guide
Yes, its working and its getting internet connection from another router. I only use CBR750 as wifi router so i don't use coax connection.
- plemansMar 24, 2021Guru - Experienced User
That's why you're having issues with the lights blinking.
Its searching for a modem connection when its not setup as a modem.
That model doesn't have an option to disable the modem portion.
Why are you using a different modem? The CBR750 has a docsis 3.1 modem and is one of the more advanced modems out there.
Im using fiber connection instead of coaxial unfortunately
