Freemaak
Aug 21, 2021Guide
CBR750 Fails after firmware update
I recently updared the firmware on my Orbi CBR750 to the latest v4.6.3.6_2.0.48 update. I can no longer establish internet connectivity. Prior to updating my connection was fine with no issues. My ISP...
Aug 22, 2021Guru - Experienced User
Ok, let us know how the RMA goes...
Avoid doing the 30-30-30 reset. Its not needed. Only a 15second press will do.
Wndrbread
Aug 23, 2021Guide
Hey…I am going this very same issue myself. Unit is no longer covered under support…but still covered under warranty until December. What do I do?
ISP came out today…no issues on their side. RJ6 had a solid signal all the way to the box.
Offered a substitute box to hold me over, elected to come on here first (hoping to find an answer).
- FURRYe38Aug 23, 2021Guru - Experienced User
Contact NG support to see what your warranty options are.
Offered a substitute box to hold me over, elected to come on here first (hoping to find an answer). - FreemaakAug 23, 2021Guide
I still haven't technically been approved for a replacement. You will have to troubleshoot multiple times with multiple techs. They will want you to purchase a gearhead support service. I gave up honestly, because their "customer service" is a joke. Four days of calling across 7 hours, and 8 different techs all having me do the same BS. Good luck...you'll need it.
Did you return your CBR?
- Blanca_OAug 24, 2021NETGEAR Employee Retired
Hi Freemaak Wndrbread CJStephens JJBabel
Kindly send me a private message with the support case number. We are currently checking on the issue.
Thank you!
Blanca
Community Team
