Kathleenmaura
Sep 11, 2022Aspirant
CBR750 not connecting to internet
I am having the EXACT same issue, exact same error message, Have reset, updated, everything suggested (internet provider recognizes unit).
What resolution paths are available?
Kathleenmaura
Thanks, but I have seen your post before:
No, can get into the CBR site, but we have reset the cable modem to factory reset, followed all instructions to connect to Xfinity, Xfinity says they recognize the device, then go back to orbi and get the error. Have retried about 10 times today. Waste of $600....
Could not retrieve all the headers
Tinyproxy was unable to retrieve and process headers from the remote web server.
Generated by tinyproxy version 1.11.0-rc1.
Sep 12, 2022Guru - Experienced User
With the ISP coax cable disconnected from the CBR, press the reset button for 10 seconds then release. Have one wired PC connected to the back of the CBR. See if you can access the CBR after about 1 minute at 192.168.100.1 in a web browser.
If you can't get to the CBRs web page, I recommend you open up a support ticket:
https://my.netgear.com/support/contact.aspx
