DrRod
Dec 11, 2022Aspirant
CBR750 not connecting to internet
I had this exact issue this week when I did a factory reset on my CBR750 Orbi modem router. When I followed the Orbi app instructions, there’s a point in the process where they tell you to exit the a...
- Dec 19, 2022
No. Please see my first post on December 11th. I am replying to someone else’s problem with the same issue to let folks know how I was able to resolve it. Hopefully, when folks look it up and see this thread, it will help them resolve it more quickly.
Dec 12, 2022Guru - Experienced User
Who your ISP?
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC as web browser. So this with the CBR disconnected from the ISP service coax line.
Use MS Edge browser to walk thru the setup wizard.
Clear out all browser caches before entering the RBR setup wizard at 192.168.1.1.
- DrRodDec 19, 2022Aspirant
My ISP is Xfinity.
No factory reset had been performed since my firmware update, which I did when I installed it this past summer. The router was brand new this summer when I installed it. When I did the factory reset, it said the firmware was up-to-date after I got it connected and checked. I didn’t use the wizard or the app; I just went direct to the router through the browser.
I do not own a PC, I use Mac.
I don’t remember the current firmware, but it is the most up-to-date.
- FURRYe38Dec 19, 2022Guru - Experienced User
So are you still having problems getting the CBR to connect to the internet and ISP services?
