pbert
Nov 10, 2021Aspirant
CBR750 not connecting to RCN
I just got a CBR750 second hand and am having trouble connecting to RCN. When the router boots up it gets to the final "online" light flashing but that light never turns solid. I've noticed the light...
- Nov 17, 2021
Thanks for the help. RCN had to send a technician out and he said the power levels were a little high (~12 [dBmV I assume]). He was able to get it working, though.
pbert
Nov 11, 2021Aspirant
Thanks for the reply. The coax cable does have a splitter right before connecting to the service box. If I can't get it working otherwise, do you think a female to female adapter would be OK or does it need to be one cable from the service box to the modem? We do not use the other cable running from the splitter it can definitely be removed.
I tried a full power off and power up cycle a few times, but still no solid online light. I also tried upgrading to the latest firmware (4.6.5.8).
Is this the connection status you were referring to?
Spoiler
Startup Procedure
Downstream Bonded Channels
Upstream Bonded Channels
Downstream OFDM Channels
Upstream OFDMA Channels
Current System Time: Thu Jan 1 00:11:02 1970System Up Time 00:10:58
| Procedure | Status | Comment |
| Acquire Downstream Channel | 363000000 Hz | Locked |
| Connectivity State | In Progress | Not Synchronized |
| Boot State | In Progress | Unknown |
| Security | Disabled | Disabled |
| IP Provisioning Mode | In Progress | Unknown |
| Channel | Lock Status | Modulation | Channel ID | Frequency | Power | SNR | Correctables | Uncorrectable |
| 1 | Locked | QAM 256 | 17 | 363000000 Hz | 7.5 dBmV | 40.9 dB | 0 | 0 |
| 2 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 3 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 4 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 5 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 6 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 7 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 8 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 9 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 10 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 11 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 12 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 13 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 14 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 15 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 16 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 17 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 18 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 19 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 20 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 21 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 22 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 23 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 24 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 25 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 26 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 27 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 28 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 29 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 30 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 31 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| 32 | Not Locked | N/A | N/A | 0 Hz | 0.0 dBmV | 0.0 dB | 0 | 0 |
| Channel | Lock Status | US Channel Type | Channel ID | Symbol Rate | Frequency | Power |
| 1 | Locked | ATDMA | 2 | 5120 Ksym/sec | 30350000 Hz | 40.5 dBmV |
| 2 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 3 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 4 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 5 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 6 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 7 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| 8 | Not Locked | N/A | Unknown | 0 Ksym/sec | 0 Hz | 0.0 dBmV |
| Channel | Lock Status | Modulation/Profile ID | Channel ID | Frequency | Power | SNR/MER | Active Subcarrier Number Range | Unerrored Codewords | Correctable Codewords | Uncorrectable Codewords |
| 1 | Not Locked | 0 | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0~4095 | 0 | 0 | 0 |
| 2 | Not Locked | 0 | 0 | 0 Hz | 0.0 dBmV | 0.0 dB | 0~4095 | 0 | 0 | 0 |
Nov 11, 2021Guru - Experienced User
Ya remove the splitter. A barrel connector can work.
Um, you only have 1 channel locked in for both UP and Down. There should be more channels locked in.
Power maybe high on the 1 channel.
You need to contact your ISP and have them check your line and check the connections status page on the CBR. You should have several Download Channels locked in.
- pbertNov 17, 2021Aspirant
- FURRYe38Nov 17, 2021Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
