España
Apr 26, 2022Aspirant
CBR750 not connecting to the internet
The internet provider was doing some service on the main line and connection was lost for most of the day. When internet service resumed the Orbi would not connect to the internet. Xfinity claims t...
Apr 26, 2022Guru - Experienced User
1. what modem/gateway is it connected to?
2. did you power off the modem/gateway and the router for a couple minutes, disconnect everything from both (even coax from modem), power the gateway back on after reconnecting the coax, wait 2 minutes, connect the modem back to router, then power it on?
- EspañaApr 26, 2022Aspirant
This is the router/modem combo. I’m trying to help out my parents. They’re in Florida and I’m not. I believe he said that he had the power off, tried resetting it from the back and still nothing.
I remembered on mine that I had to hard connect to the orbi with my laptop and then go to orbilogin.net. I just can’t remember what I did afterwards. We both have the same system.
- plemansApr 26, 2022Guru - Experienced User
Are they able to access it through a hardwired connection?
Is it a new unit? (if so, there's 90 days of free support through netgear)
Is the ISP able to ping it? If so, they can always send a reboot signal to it
No it’s a over a year old. I told him to try and hardwire it but I haven’t heard back from them. I’ll call them in the morning to find out their progress. I remember on mine that I had to use my mobile hotspot to get my laptop to work and then hardwire it to the orbi to do something to get it to work.
- FURRYe38Apr 26, 2022Guru - Experienced User
What do the front leds indicate?
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
