zigor911
Feb 10, 2023Aspirant
CBR750 not tranmitting
Hello, have very the same issue with CBR750. Since Fall of last year either after NG FW update and/or xFinity work, my CBR750 stopped responding back to Comcast, xFinity app always shows as it is off...
zigor911
i was suggested by xFinity to upgrade from 400 to 800 plan based on number of my connected smart devices (which is BS to me, but i decided to give it a shoot), didnt change anything. I started with CBR750 back in August of 2021 with 3 satellites. Everything worked well, would loose connection once every 2 weeks or so, and Modem was transmitting back to xFinity so i saw it being online. But for the last 6+ months, after several FW upgrades from NG and "service improvements" performed by xFinity in the area, things got progressively bad. Dropping connections, not transmitting back to xFinity so it reported off line all the time. Local head tech tried to help, he run a new cable from street poll to the house, no splitters (except inline connector for grounding and inline power reducer to keep signal strength within NG guidelines). My modem is still dropping connection every 2 days or so. I am beyond frustrated.
Feb 10, 2023Guru - Experienced User
What state are you located?
I see some Correct and Un-Correctables that should be zero'd like the other channels.
Power look ok.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
Please post a copy and paste of the modems event log page.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
https://kb.netgear.com/000062081/How-do-I-erase-the-configuration-settings-on-my-Orbi-WiFi-System?
