patrickrowan
Feb 17, 2023Aspirant
CBR750 not tranmitting
i'm having the same issue, any update?
Feb 17, 2023Guru - Experienced User
Who is the ISP? CC or XF?
What ISP Speed tier package do you pay for UP and Down?
Has this been always happening or just started?
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
- patrickrowanFeb 17, 2023Aspirant
Thanks for your help
Xfinity 1000 down 20 up
Originally started 6+ months ago not being able to connect to my modem from xfinity but service otherwise was ok
Last month they "upgraded" my area and i've had to reboot the modem almost daily
FW version V4.6.14.4_2.3.12
Nothing in event log, attaching connection status and will dm you my serial/mac
- FURRYe38Feb 17, 2023Guru - Experienced User
I've passed this onto NG, someone should be making contact with you.
